what will i run
Old Jan 24, 2013 | 07:27 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
what will i run
I have a 355 sbc. I'm curious on 1/4 mile and hpestimates. Specs below.
350 0.30 over
210cc aluminum heads 2.02/1.60 valves
Roller rocker arms
Edelbrock cam .488/510 duration is 230/240
Air gap intake
Holley 670 street avenger
Msd ignirion
14* base timing
Hooker headers to true duals
Stripped interior of anything usless
Procar racing seats
3.73 gears
275/15 rear drag radials
Turbo 350 trans
2800 stall
Old Jan 25, 2013 | 12:26 AM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: what will i run
You're going to need to be a lot more specific than that if you want a somewhat decent guess.
Overall compression? What heads? Are they modified? Is the intake ported and/or matched? What ratio rockers? What TYPE of headers? What rear? What kind of converter? Modifications to the carb? Cam is (I am assuming) a hyd. flat tappet? Miles on the motor? What altitude are you running at? Suspension modifications?
Need as many specifics as you can get, otherwise your question is just a shot in the dark..
Oh, and you made two posts on the subject.. why?
Old Jan 25, 2013 | 07:59 AM
Engine: 355
Re: what will i run
ACCIDENTAL
350 0.30 over- 55235 APRROX MILES
210cc aluminum heads 2.02/1.60 valves- PRO COMP.
Roller rocker arms-3/8 1.5 RATIO
Edelbrock cam .488/510 duration is 230/240-FLAT TAPPET
Air gap intake-MATCHED PORTS
Holley 670 street avenger- STOCK
Msd ignirion
14* base timing
Hooker headers to true duals- HOOKER HEADERS 25/8 PRIMES TO 3 INCH
Procar racing seats
7.5 TEN BOLT WITH 28 SPLINE MOSER AXLES C CLIP ELIMINATORS
3.73 gears- DETROIT LOCKER
Turbo 350 trans
2800 stall-
STOCK SUSPENSION WITH FRONT SWAY BAR REMOVED
UNSURE COMPRESSION MAYB 9.8-10.1ISH
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
