350 build
Car: 1987 iroc z
Engine: 305 tpi for now
Axle/Gears: 3:24
350 build
i have a 350 i built for my 87 iroc, havent installed it yet.
mid 70's 350 601 heads 58 cc 2.02 1.94 valves, ported and polished. stock pistons, cam is .218 @ .50 .450 lift. 274 dur. 106 lobe seperation. .025 deck. .015 head gasket. edelbrock 650, generic aluminum dual plane. long tube headers. sounds good but like i said not installed yet estimated compression ratio is 9.7:1 im running 91 octane through it. does anyone have any comments or advise. hp estimates? im not going to change my build. and its going to be paired to a rebuilt 700r4 with b&m shift kit. stock stall. it will work with cam though.
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Re: 350 build
Really hard to say without knowing some flow specs on the heads
Could be 300 325 350who knows
Eric-86sc
Aug 24, 2015 09:01 PM
