305 to 350 part swap-ability
Old Feb 4, 2013 | 09:38 AM
Chuck84TA's Avatar
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
I wanted to start a thread that addresses the long-standing, sometimes heated discussion on the "build up the 305" versus "install a 350" subject.
From what I have surmised with the vast knowledge and opinions I have seen exposed on this subject, it appears that there are 3 items that can be swapped over to a 350 from a modified 305.
1) Cylinder Heads-
Some aftermarket (World torq, Edle, Trick flow) and some GM cylinder heads-(ZZ4/L98 aluminum for example) can be swapped over. Better breathing heads (not to mention the weight savings of aluminum) can really wake up a 305.
Estimated Cost- New- 800-1200 (I have seen used heads on Ebay go for 1/2)
2) Headers-
SLP,Hooker 2055's, Dyno Dons- Since the headers attach to the cylinder heads, this is a straightforward swap.
Estimated Cost 700-900
3)Camshaft-
If the Cylinder heads can take the lift of the cam, then barring any ECM issues, this can also be "portable".
Estimated cost - 200
Total Cost - $1700- $2300..
Granted you can buy a NEW 350 crate for that total, but you'd have a 350 without quality heads/cam. Imagine buying a 350 crate motor for $1700 then swapping over the ZZ4 head and cam....Now you've got a 350 that probably can push 400hp/Tq...For less than a ZZ4!
The thing is, there is NO cheap way to build a 305 motor up. But if you are willing to incrementally increase the performance of your vehicle, it may be a good idea.
I think if you plan to own your vehicle for a long time and have some time AND desire to pull the engine and get the hands dirty (like me, God willing) doing a slow build up with the 305 and swap over the parts to a 350 block seems sensible to me.
I look at is as a long term/slow financial money pit drip versus a one time wham bam wallet buster way to build up some much needed performance.
Still willing to learn
Chuck
Old Feb 4, 2013 | 10:00 AM
Chuck84TA's Avatar
Re: 305 to 350 part swap-ability
Also, consider this. If you were to spend $1700 on a 350 but you are still running the stock iron manifolds, well....then you cannot add $700-900 to the cost difference to a 305 buildup since you will need the aftermarket headers anyway.
Reborn756
Sep 4, 2015 03:42 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
armybyrd
Aug 10, 2015 09:23 PM
1nastygta
Aug 8, 2015 07:38 PM
