Need HELP with codes
Car: 86 bronco, 88 iroc
Engine: 351 windsor, 350 tpi
Transmission: 700r
Codes are 32, 36, 42, 43Just had the engine and trany rebuilt, when I turn car on in the morning and drive a couple miles the SES light turns on and the car runs and idles real bad, two nights ago I had to pull over cause it was heating up, when I opened the hood I noticed that the exhaust manifold were glowing red hot. My first thought was a cloged converter, the next morning I removed the converter and noticed it was cloged I couldn't see daylight. I ran it noticed a big difference in power, now this morning drove to work and on the freeway it start losing power then SES turned on and car starts losing even more power and start heating up, and I also smell fuel.
I've spent a lot of $ already on the rebuilds so I need you guys help reading these codes and finding out what's going on. I want to do it myself if possible so I would truly appreciate any help. Thank you in advanced.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Need HELP with codes
with all of those codes at once you should start with checking your ecm ground behind the passenger side cylinder head. This sounds like you might have a bad ecm.
