vacuum ball , important??
Old Feb 7, 2013 | 02:36 AM
thatoneguy5x's Avatar
Car: camaro
Engine: 3.1
Transmission: auto
simply put what does it acutally do and is it necessary? i know it stores vacuum but for what?
Old Feb 7, 2013 | 05:06 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: vacuum ball , important??
So the vent positions don't change every time you accelerate for one
Old Feb 7, 2013 | 08:11 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
And helps the cruise control do its thing.
Old Feb 8, 2013 | 04:09 PM
Car: camaro
Engine: 3.1
Transmission: auto
i see but does it affect its drivability or performance? idle,acceleration, etc?
Old Feb 8, 2013 | 04:33 PM
TTOP350's Avatar
Unhook the hose and see what it does.
Old Feb 8, 2013 | 11:06 PM
Car: camaro
Engine: 3.1
Transmission: auto
the thing is it hasnt been connected since i bought the car. i was planning on hooking it all back up but i wanted to figure out what it was actually for
Old Feb 8, 2013 | 11:08 PM
TTOP350's Avatar
Well hook it back up and see if there is a difference. If the hose was rotted out you would have a vac leak which would cause some problems.
Old Feb 9, 2013 | 01:00 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Has noting to do with the engine operation.
Is only a reserve container to maintain a constant vac supply when the engine vac changes; like when you accelerate
Old Feb 9, 2013 | 06:35 AM
Damon's Avatar
Without it when you nail the gas your HVAC will move to the default (defrost) position and then will return to wherever you set it once you let off the gas again. Not that the lever will move, but that's where the air will blow out during periods of low intake manifold vacuum (like at WOT).
Old Feb 10, 2013 | 03:24 PM
Car: camaro
Engine: 3.1
Transmission: auto
thanks every1 for your replies hooked it all back up
Pac J
May 17, 2020 10:44 AM
Ed1LE
Sep 30, 2018 09:14 AM
88CamZ
Oct 8, 2015 10:29 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
