msd time
Old Feb 12, 2013 | 11:28 PM
bears41666's Avatar
Car: 1991 camaro rs
Engine: 350 bored .030 over, 438rwhp 429tq
Transmission: 700r4 stage 3 race 700hp
Axle/Gears: stock axles and 3.23 gears
msd time
im looking to buy a msd 6a, i was ondering if anyone has used something like this http://www.jegs.com/i/MSD+Ignition/121/8401/10002/-1 and how hard it was to install and if they needed anything extra for it
Old Feb 13, 2013 | 01:10 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: msd time
Why would you do that?
If you really want a MSD coil buy this and put it in your HEI dist
http://www.summitracing.com/parts/msd-8225
Then you don't need a new remote coil as well as the #8401 conversion cap you linked
Old Feb 13, 2013 | 11:23 AM
bears41666's Avatar
Car: 1991 camaro rs
Re: msd time
then how would i hook the msd box up to that
Old Feb 13, 2013 | 11:58 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: msd time
That is for old hei so you can run an external coil, which your 91 already has.
It will not do anything for you in terms of hooking up an msd box.
When all else fails, go to the companies website, I did the hard part for you,
http://www.msdignition.com/appguidedomestic.aspx
You need 8876 harness to install the 6a box.
Don't expect a huge gain in performance if your engine is mild.
Old Feb 13, 2013 | 04:37 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: msd time
Pg 12 ;how to wire GM Ignition
http://static.summitracing.com/globa...1_frm29772.pdf
Old Feb 13, 2013 | 04:44 PM
Twin_Turbo's Avatar
Re: msd time
get an al2!!! much more compact and digital, unlike the analog al.
BRoss99
Aug 10, 2025 05:08 PM
toronto formula
Nov 10, 2015 06:17 AM
theurge
Aug 21, 2015 12:46 PM
midias
Aug 15, 2015 05:07 PM
tartagliaz28
Aug 15, 2015 10:59 AM
