What 'brand' for roller lifters?
Old Feb 15, 2013 | 11:32 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
I just realized the title says Rockers. I'm asking about lifters.
Gathering parts for my build.
I have a comp hyd roller cam and matching valve springs.
I am wondering if I should be new Comp lifters or GM?
I know there are some Comp haters here, and the GM ones are cheaper.
There was an article in a recent hot rod magazine talking about mix and matching brands of valvetrain parts and the problems that can happen, regarding different harmonics or something, which made me a little concerned.
This build is a mild TPI.
I haven't heard much bad about GM lifters.
Thoughts?
Old Feb 15, 2013 | 11:48 AM
IrocRoadRacer's Avatar
Car: 1989 Camaro Iroc Z
Axle/Gears: 9 Bolt Borg Warner/ 2.77 gear
re: What 'brand' for roller lifters?
PRW 1.6 RR's; Installed them half a year ago, and they work great.
Old Feb 15, 2013 | 12:15 PM
Car: 1971 Camaro
Engine: 427
Title is wrong, asking about lifters not rockers.
Old Feb 15, 2013 | 01:26 PM
Car: 1971 Camaro
Engine: 427
I also hear LS7 lifters are where its at these days. Thoughts?
Old Feb 15, 2013 | 05:53 PM
TPI will protect the lifters from ever making even the slightest detectable difference.
Use whatever's cheeeeepest. (within reason... don't turn into a bottom-feeder) Probably GM.
Half a year is the blink of an eye. That stuff is not even broken in yet, or at least, shouldn't be. Not enough experience to be giving advice on that basis. Yeah it didn't fail the instant you hit the key; but it's hardly out of the "infantile" time frame yet. ESPECIALLY if it's not COMPLETELY a PRIMARY TRANSPORTATION daily driver.
Old Feb 15, 2013 | 09:15 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Unless your L98 lifters are FUBAR for some reason, just reuse them.
{Fixed the title for you}
Old Feb 16, 2013 | 07:27 AM
Car: 1971 Camaro
Engine: 427
Re: What 'brand' for roller lifters?
Thanks for the edit!
My stock lifters are MIA.
That said, I can get a set of NIM Pro Comp lifters for $65. I've always been a little leary of their stuff though.
New GM lifters will be about $150.
I just want a set that will last 100,000 miles. GM is probably the way to go, but the price savings of the prop comp ones would help.
Old Feb 24, 2013 | 03:52 PM
Car: 1971 Camaro
Engine: 427
I went with new GM lifters from jegs.
TX-SleeperC5
Feb 24, 2016 01:34 PM
Stryker412
Sep 7, 2015 09:11 AM
dimented24x7
Sep 6, 2015 03:51 PM
SG91camaro
Sep 5, 2015 10:27 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
