1 Wire to 3 Wire Oil Pressure Switch / Sender?
Old Feb 17, 2013 | 03:08 PM
oscarfromla's Avatar
Car: 88 Iroc-Z
Engine: 355 AFR-195 FIRST Fuel Inj.
Axle/Gears: ??
My 88 5.0 IROC came with the single wire oil pressure sender, and the 2 wire oil pressure/fuel pump power switch. Is there any reason why I can not install the combined oil pressure switch / sender (OPS) from later Camaros (89 & up or LT-1) and have it function properly?
I already have a 3 wire pigtail that I can splice in but I'm not 100 percent sure the ohm values are the same for the two different style oil pressure senders.
Old Feb 17, 2013 | 03:28 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: 1 Wire to 3 Wire Oil Pressure Switch / Sender?
It will work just fine, one of the things I do all the time.
Old Feb 17, 2013 | 03:30 PM
Car: 88 Iroc-Z
Axle/Gears: ??
Perfect, thanks Don.
89GTAOz
May 16, 2020 09:31 AM
Caspar
Jun 19, 2016 11:19 PM
TA8487
Aug 16, 2015 12:21 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
