popular penetrating oils
Old Feb 19, 2013 | 01:01 PM
danclemts's Avatar
Car: 1985 Volvo turbodiesel
Engine: 1989 305 TPI in the Volvo
Transmission: 1990 700r4
Axle/Gears: 3.73 Dana 30
I recently read this in another forum ("Machinist's Workshop") and thought I would post their findings here. The magazine reports they tested these products for "break out torque" on rusted nuts and bolts. A subjective test was made of popular penetrating oils, with the unit of merit being the torque required to remove the nut from a "scientifically rusted" bolt. Average torque load to loosen nut:
No Oil used..........516 ft lbs
WD-40 ...............238 ft lbs
PB Blaster ...........214 ft lbs
Liquid Wrench ......127 ft lbs
Kano Kroil ...........106 ft lbs
ATF/Acetone mix....53 ft lbs
The ATF/Acetone mix is a "home brew" mix of 50/50 automatic transmission fluid and acetone. Note this "home brew" released bolts better than any of the commercial products in this one particular test. Our local machinist group mixed up a batch, and we all now use it with equally great results. Note also that Liquid Wrench is almost as good as Kroil for only 20% of the price. ATF/Acetone mix is best, but you can also use ATF and lacquer thinner in a 50/50 mix. ATF = Any type of Automatic Transmission Fluid.
Old Feb 19, 2013 | 01:58 PM
lonestar7's Avatar
Car: 1988 Firbird formula 350
Engine: 5.7L TPI
Axle/Gears: 3.27 Nine Bolt
Re: popular penetrating oils
I've worked on enough of them to know: no two rusted bolts are created equal. Just wondering how they created uniformly rusted test bolts? That is, if you sprayed all the bolts with BP Blaster, how close would each one be to the 214 ft-lb average they give? I often use a combination of light oil and acetone on corroded screws and threaded barrels on the photographic equipment I repair for a living, and I have no doubts it will work. I'm just not convinced it's 4 times better than PB Blaster. The acetone is an excellent wetting agent and it "wicks" the oil along with it into the threads. Acetone is very flammable and can damage some plastic and synthetic rubber parts, so you need to be careful with it. I'll have to remember this and give it a try the next time I do some under car work where the worst rusty bolts seem to live.
Old Feb 19, 2013 | 02:08 PM
danclemts's Avatar
yea, You are correct on the testing setup, hopefully they found a way to make the rusted bolts uniform. Still interesting info, always nice when something cheap works well
jrdturbo
Mar 31, 2016 02:58 PM
bigjay89gta
Oct 15, 2015 08:04 AM
skinny z
Oct 5, 2015 06:23 PM
mfp189
Sep 27, 2015 09:25 AM
