Cranks but no start this morning
Car: 92 Camaro RS
92 camaro with 350 engine was running fine last night. Whet to start it this morning and all it does is crank. Fuel pressure guage I have on aftermaket regulator shows good fuel pressure. Could a malfunction of the VATS system prevent the injectors from firing?
Car: 92 Camaro RS
Re: Cranks but no start this morning
No security light flashing.
Did some checking this evening. I am getting no spark out of the coil. I am getting 12 volts to the coil. Unhooked the harness to the distributor at the coil and have not power there. So would you think a bad coil or a bad module in the distributor? Thanks.
Car: 92 Camaro RS
Was a bad ingnition control module. Put in a 20 year old one and it runs better than the 4 month old one from JEGS ever did. Good quality JEGS.
backtothe80s
Sep 5, 2015 12:39 AM
