how to fine tune??
Old Feb 21, 2013 | 02:43 PM
85irocz86's Avatar
how to fine tune??
Hi I have a 85 iroc , just freshened up motor it has 11:1 comp, world products heads , I changed the injectors and put in 24lb inj. Also have accel lower intake and slp runners. Edelbrock headers. New cap rotor (msd) new esc module, wires. Egr delete plate. Also have a comp xfi cam 268 280. I had a custom chip burned to match what I had done already but it does not seem right I still have stock throttle body 48mm and stock plenum. I am not sure what fuel pressure is at that's next or if pump is putting out enough or not ?? It sounds like there is sputtering or spitting out of exhaust. If neones has ne input it would be greatly appreciated and how much HP could this set up put out?? If tuned correctly.
Old Feb 21, 2013 | 05:30 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: how to fine tune??
Originally Posted by 85irocz86
I am not sure what fuel pressure is at or if pump is putting out enough or not ?? .
That would be a starting point
Need a pressure gauge to check.
Should have stock pressure .43 psi with vac line to the reg disconnected ; 39 psi with line connected
Who did the tune?
Old Feb 22, 2013 | 03:08 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
If this is a 305 engine, then your 24 lb/hr injectors will put you about 35% too rich at WOT, and probably max out your negative blms at idle, possibly fouling the plugs. If 305 cid engine, then you need to change the injector constant in the chip to lean it back down. If 350 cid you still may need to adjust the injector constant some if you're getting a lot of negative blms.
Hook up a scanner and/or WBO2 and see where you're at now.
This step will probably take care of at least 80% of the fuel tuning required.
Bubbajones_ya
Jul 6, 2024 08:32 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Eric-86sc
Sep 7, 2015 02:10 PM
