Where can you buy a windshield washer checkvalve?
Transmission: World Class T-5
Axle/Gears: BW 3.45
Rock Auto had them last year. Now I can't find a source for them anywhere.
Transmission: 4L80E/4L80E
Have you looked in the "HELP" section of the parts store?
Axle/Gears: BW 3.45
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Where can you buy a windshield washer checkvalve?
I would imagine that a check valve off of just about any car would do the trick of preventing the juice from draining back into the bottle. If you are worried about aesthetics, the valve is located in a not-to-obvious location if I recall.
HEY! Why are you washing your windows with the wipers? Your baby wants you to clean the windows personally.
Axle/Gears: BW 3.45
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
JamesC
Axle/Gears: BW 3.45
I'd take a used one, if I could find one.
Axle/Gears: BW 3.45
Oh, one more thing, James. This checkvalve is only on my '85, not the other two. Now that you've confirmed this an OEM piece, I think I'm just going to try and repair it.
Car: check
Engine: check
Transmission: check
Never knew that GM put a check valve on the WW line. Learn something new everyday.
Would a vacuum line check valve work? If so here is the GM/AcDelco number for it:
14047619
RBob.
14047619
RBob.
Axle/Gears: BW 3.45
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Originally they didn't, but customers complained it took too long to clear the windshield after mud or something splashed on it. IIRC first there was a recall to reroute the hose to prevent it from draining back and later the check valve was added.
I don't use the wipers, front or rear, so though I have the check valve(s), the fluid drains. In order to pump fluid, I have to prime. A mouthful of windshield wiper fluid is distasteful at the very least.
Interesting, I'd imagined that all cars were so equipped.
The first pic is the rear wiper valve, the second the front.
JamesC
JamesC
Axle/Gears: BW 3.45
So the pink/green check valve was added during a recall and not at the factory? Interesting.
Interesting. My '82 had it.
As for my "HELP" suggestion, I had forgotten that I had looked, and ended up getting a tube of Super Glue to fix mine. Sorry.
Axle/Gears: BW 3.45
Yup, I'm fixing mine. Where could you possibly find a pink/green period thingamajig like that? I was thinking epoxy, but super glue would do the trick.
Bohemian
Aug 15, 2017 05:11 PM
Saxondale
Exterior Parts Wanted
Sep 16, 2015 06:32 AM
Saxondale
Sep 7, 2015 06:11 PM
Saxondale
Exterior Parts for Sale
Sep 7, 2015 11:40 AM
