l98 oil pressure gauge install and temp
Old Mar 3, 2013 | 03:23 PM
s10sbc350's Avatar
Car: 91 Z28 camaro
Engine: L98 from 90-92 camaro
Alright well I need some help getting a oil pressure,oil temp, and water temp gauge installed, so that when i get my motor running agin I can have working gauges. Its mainly the water temp, and oil pressure gauge i need to get connected first, and basicaly i need to know what i need to buy off ebay, and where the oil pressure and water temp gauge connections are on the motor, and a picture would be the best.
Old Mar 5, 2013 | 04:38 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Water temp: Driver side head, between the 1st and 2nd spark plugs (technically, between cylinders 1 and 3).
Oil pressure: On the block behind the intake manifold, beside and a little behind the distributor toward the driver side, is a port. Some blocks also have a port about the oil filter mount.
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
ChevyZ71
Aug 13, 2015 07:30 AM
