Stalling in gear?
Old Mar 7, 2013 | 05:31 PM
zephyrinias's Avatar
Car: 1983 Trans Am
Engine: 5.0L Crossfire TBI
Stalling in gear?
I have a 1983 Crossfire Trans Am, when the car is in park, it idles fine. When I come to a stoplight or am sitting for a few minutes, the idle drops to around 500 and dips, occasionally stalling the engine. When it dips, the engine tries to bring the idle back up, but eventually it just falls back down to the same RPMs.
It was driven daily by the owner I bought it from, stored (and maintained) for 10 years by the owner before him. I changed all fluids, fixed a number of vacuum hoses (not sure if I missed any) It leaks a bit, not much, and I can't really identify where from.
This is my first third gen, and I really want to get her at least in comfortable driving condition, so I can start focusing on aesthetics.
Any ideas what could be going on?
Old Mar 7, 2013 | 05:35 PM
Car: 1983 Trans Am
Re: Stalling in gear?
Oh, I need to add that this was not occurring when I purchased the car.
Old Mar 8, 2013 | 08:52 AM
freshZ28's Avatar
I've heard the iac valve can be the culprit of these symptoms. try cleaning the iac valve, throttle body iac valve ports with maf sensor cleaner and put Teflon on the threads if the gasket for the iac breaks and see if it cures the problem.
Posted from Thirdgen.org App for Android
Old Mar 11, 2013 | 02:29 AM
Car: 1983 Trans Am
I'll give it a shot in the morning, and let you know what the outcome is.
There was a vacuum hose heading to the EGR valve from the back of the front tb that I had reconnected (didn't realize it was unhooked) then the fluxuation in RPMs got worse, and it dies in park. I took it back off and nothing.. it didn't change a thing. It stayed worse than it was, and when I give it gas, the engine shakes violently. (mounts are good) still dies a few cycles of up and down with the RPMs
I definitely will check the EGR and IACs, but can they really cause something this dramatic?
Old Mar 11, 2013 | 10:36 AM
freshZ28's Avatar
There was a vacuum hose heading to the EGR valve from the back of the rear tb that I had reconnected (didn't realize it was unhooked) then the fluxuation in RPMs got worse, and it dies in park. I took it back off and nothing.. it didn't change a thing. It stayed worse than it was, and when I give it gas, the engine shakes violently. (mounts are good) still dies a few cycles of up and down with the RPMs
if those two things are bad, its a strong possibility, have you done the vacuum test to the egr ?
Old Mar 11, 2013 | 10:44 AM
freshZ28's Avatar
Old Mar 11, 2013 | 07:00 PM
Car: 1983 Trans Am
I pulled one of the IACs today and this is what it looked like. (Couldn't get the other one because I'm not at home and don't have the right wrench) Is this an excess amount of carbon? I'm sure the other one is equally as nasty.
Vacuum tested the EGR and it seems fine.
Am I supposed to relatively easily be able to pull/push the pintle in/out?
GTAman
Jul 3, 2024 07:29 PM
IROCtometal
Sep 9, 2015 10:01 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
