tps signal and trans Q. stumped chime in techs
ok i'm back i have bought an 88 irocz 5.7 auto . ok this car has been sitting in a garage for a long time i purchased from a long time friend. i've just about went thru it top to bottom.
my question is does the tps sensor control shifting in these cars it has been so long since i worked on one i'm rusty.
the problem i am having is it it doesn't want to shift when accelerating unless i let off the fuel. easy cruising it will shift fairly good. it still shifts kinda high in the rpm range but it shifts. i haven't read the voltage on the tps as of yet but there was no code prior to me unplugging it. i reset the computer and it wasn't there but still did the same thing. the trans has plenty of fluid. another thing when i am driving and i go to manually shift it down thru the gears it goes from od, to d , then when i go to 2nd nothing and same with first. i've been searching but things have change a lil in the four years since i've been on.
any insight or help would be greatly appreciated. oh and i did the tv adjustment same thing
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: tps signal and trans Q. stumped chime in techs
I'm no expert but can say with certainty that the TPS has nothing to do with shift points on a TPI car.
BumpaD82
Feb 26, 2016 02:57 PM
