Dropping Engine and Tranny?
Old Mar 8, 2013 | 01:54 AM
AKcamaroAK's Avatar
Car: 1986 Chevrolet Camaro Z28
Engine: 350 V8 4bbl
Transmission: Automatic 700r4
Axle/Gears: 2.73 Open Diff
I'm pulling the engine and tranny out of my 86 z28, and everything at the moment is disconnected and unbolted except the distributor and whatever wiring in behind it. I heard the easiest way to get them out if dropping it down out of the car on a lift. How would I do this though? tranny hoists and screw jacks is the only thing I can think of. Or would it just be easier to pull it all out the top with a crane?
Old Mar 8, 2013 | 07:05 AM
Re: Dropping Engine and Tranny?
It is MUCH more difficult to do the FWD thing in these cars, than the traditional way.
Pull it out the top.
I'd suggest leaving the trans in place and dealing with it separately. Others may suggest otherwise; but I generally find it's ALOT easier not to have some big long heavy unbalanced swinging dripping thing hanging off the back of the motor while wrestling with it.
Old Mar 8, 2013 | 08:12 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Ditto. It would be in my opinion easiest to pull from top without trans connected.
Just need a long enough arm hoist, as mine will hit front bumper before getting all way back to motor, so i go from the side with hood off the car and wheel off the car
Old Mar 8, 2013 | 09:40 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
This is how I do it. Car on my lift, hoist on side with hood on. (I have done a buttload of them this way, 500 plus)
Old Mar 8, 2013 | 09:18 PM
UBHSTRY's Avatar
Im not sure you could drop it thru the bottom, could you?? Thats the way for allot of the newer cars. Use a picker, like they have all said. I go from the front. I have pulled both ways, with and without the tranny. W/O the tranny is the way to go on these cars. Its not that hard to unbolt it, and just take your plenum, runners, and distributor off, and you can easily get the top tranny bolts....and the grounds on the heads much easier/.
Old Mar 11, 2013 | 12:52 PM
freshZ28's Avatar
IMAGE#1
I can't tell from this angle, is your front end on jack stands? as high as you can get it ?
Posted from Thirdgen.org App for Android
Old Mar 11, 2013 | 01:58 PM
TTOP350's Avatar
Did you read my post you quoted??
Old Mar 11, 2013 | 02:10 PM
UBHSTRY's Avatar
It is nice having a lift, isn't?
Old Mar 11, 2013 | 02:19 PM
AKcamaroAK's Avatar
Engine: 350 V8 4bbl
thanks for the input guys, i got the engine and tranny out seperatly and it was super easy. Dropped the tranny and then pulled the engine out the top.
Old Mar 11, 2013 | 02:30 PM
TTOP350's Avatar
Checkout how the factory did it.
http://www.last1992camaro.com/pictures/page3.html
E Rod
Aug 28, 2015 05:17 AM
jharrison5
Aug 19, 2015 05:53 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
