What is this on my fuel pump?
Old Mar 13, 2013 | 01:32 PM
HiPerf_Chevyman's Avatar
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
Instead of a piece of rubber hose, Theres a Slip on connector block, from the Pump to the sending unit. Slid off with little effort. I didnt Like it, so i but a Piece of Fuel Injection hose on the new Bosch pump to the Sending unit with Fuel injection clamps. What is that block piece? a Fuel dampener of some sort? Should i put it back on instead of the rubber line? asking before i put it all back together. Thanks, Nick
Old Mar 13, 2013 | 01:38 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: What is this on my fuel pump?
pump pulse dampener, throw it away and install a hose and clamps
http://www.amazon.com/ACDelco-FP27-F.../dp/B000C9S2KE
Old Mar 13, 2013 | 01:47 PM
Car: 1991 Camaro RS
Thanks so much! I appreciate the quick response! I've done a about 100 GM Fuel pumps and ive never ran into one of these. Having it removed wont kill a Fuel pressure regulator will it? I'll find out i guess I've never had an issue with a FPR on the 90's GM's. Thanks again
Old Mar 13, 2013 | 02:00 PM
Engine: Lb9
Transmission: M20
The purpose of it is to help dampen the sound of the fuel pump going through the steel lines causing noise. Well you know what the problems are it is a common area for a leak and loss in fuel pressure.
Old Mar 13, 2013 | 02:55 PM
Car: 1991 Camaro RS
Yup, mint deal. Test drove it. Feels good, no leaks. No gas smell (probably immune to for right now) all set to go 100K again. yay im glad thats done and over with. Somebody replaced the pump before with a Carter pump. Oh brother its no wonder!!!!!!! haha Thanks Man!
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
