Worth it to swap to Serp. belts???
Old Mar 16, 2013 | 06:58 PM
cs80camaro's Avatar
Car: 1987 Iroc Z
I am in the process of picking up a Yellow 1987 IROC-Z28 305 TPI from a buddy. The engine has low miles about 61k and been sitting garaged since '00-01 about. I have a engine with drive belts from a 89 5.7 Iroc in the basement. Would it be worthwhile to swap over from V-belts to Serp. belts. how much of a hassle is the swap to do?
Old Mar 16, 2013 | 07:46 PM
manolis1969's Avatar
Car: klowny1969 <-youtube 4 3rd gen vids
Engine: subscribe to klowny1969 on youtube!
Transmission: subscribe to my channel on youtube
Re: Worth it to swap to Serp. belts???
Serps are better..especially if u mod the motor and spin it up..vbelts have a tendancy to slip off.. If u go serp..then u need a reverse rotation water pump and i beleive u need to extend the wires to the alt because it will be in a diff spot..
Old Mar 16, 2013 | 08:53 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Vbelts use less power to turn. Up to you, comes down to looks imo.
Old Mar 16, 2013 | 10:18 PM
cs80camaro's Avatar
Car: 1987 Iroc Z
OK thanks for the replies. Makes sense just to build up the L89 on the stand then upgrade everything at once down the road.
1992 Trans Am
May 10, 2023 07:19 PM
Navy8125
Aug 22, 2015 07:13 PM
mustangdmurder
Aug 21, 2015 07:17 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
scottmoyer
Aug 9, 2015 10:18 PM
