How to attach oil pick up
Old Mar 18, 2013 | 01:23 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
I dont have any way to weld/tack it on, so can i just use JB Weld to hold it in place?
Old Mar 18, 2013 | 02:07 PM
ApolloX64's Avatar
Car: 1992 Pontiac Firebird Formula WS6
Axle/Gears: 3.23 L-Slip w/ discs
Re: How to attach oil pick up
Most oil pickups are a slip fit into the pump housing with a thin coat of black silicone around it. You can put the tube in a freezer overnight and it should slip right in with a few gentle taps.
Old Mar 18, 2013 | 02:10 PM
Twin_Turbo's Avatar
Stake the housing
Old Mar 18, 2013 | 02:41 PM
drdave88's Avatar
Engine: 6.0L
Originally Posted by Twin_Turbo
Stake the housing
What do you mean stake it?
The tube is already in, but it spins around in there very easily.
Old Mar 18, 2013 | 02:56 PM
Twin_Turbo's Avatar
With a chisel punch the housing on 2 sides to secure the pickuo
Old Mar 18, 2013 | 02:58 PM
KMdoza7's Avatar
Car: 1989 IROC-Z28 Camaro
Engine: none
Transmission: T-56 W/ Spec 1 Clutch
Axle/Gears: 9 Bolt BW 3.27 Gears
I put a 5/8ths wrench around the pick up, and had my brother hold it to the pump, hold the bolt on the tip of the wrench and just hammer it in. put some oil on the end of the pick up..this is the easiest way.....i didnt read that it was already in place sorry
1992 Trans Am
May 10, 2023 07:19 PM
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
dustint209
Sep 9, 2015 08:09 AM
Navy8125
Aug 21, 2015 09:32 AM
