play allowed on valve stem inside the guides ? 350 L05
Old Mar 25, 2013 | 08:51 AM
Jabpir8's Avatar
Car: Buick RMW 92
Engine: L05 5.7L V8
Transmission: 4L60
Ok, I have removed the heads (casting 193) of my 1992 L05 350ci engine (from a 92 Caprice).
I want to check the play of the valve stems inside the guides.
Has anyone got the values ???
Are they the same if I have steel guides or bronze guides installed ?
(machine shop waiting for the figures ...)
thx !
Old Mar 25, 2013 | 11:53 AM
Jabpir8's Avatar
Car: Buick RMW 92
Engine: L05 5.7L V8
Transmission: 4L60
Re: play allowed on valve stem inside the guides ? 350 L05
I got 0.0011" max of lateral movement near the guide but someone tell me this is quite low.
Old Mar 25, 2013 | 12:17 PM
88gunmetalgta's Avatar
Intake 0.0015" to 0.0016"
Exhaust 0.002" to 0.0025"
I would say you're not getting an accurate measurement if you're getting .0011" max, and this is coming off an engine that has some mileage on it.
Old Mar 25, 2013 | 12:35 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
.001" intake and .0015" exhaust is a pretty normal target for new.
Old Mar 25, 2013 | 06:31 PM
.002" - .003" is typical for good used. Up to about .005" can be tolerated if you don't mind a slight blue puff now and then.
.0011" is not right; no way you can measure that down to one ten-thousandth of an inch.
Old Mar 25, 2013 | 07:21 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Maybe it was .011"?
Old Mar 25, 2013 | 07:31 PM
GICATA's Avatar
Car: '83 WS6 T/A 65,000 miles
Engine: 5.0L vin H stock, 406SBC right now
Axle/Gears: Corp. 3.73
.015 is what to aim for.
Old Mar 26, 2013 | 09:23 AM
Jabpir8's Avatar
Car: Buick RMW 92
Engine: L05 5.7L V8
Transmission: 4L60
OK,
so managed to get the values from a service manual (1992)
QUOTE
Stem Clearance
Production
Intake & exhaust 0.027-0.069 mm (0.0011" - 0.0027")
Service
Intake 0.093 mm (0.0037") MAX.
Exhaust 0.119 mm (0.0047") MAX.
UNQUOTE
My car has got 135,000 miles.
The measured values measured are around 0.15 mm (0.0059") MAX of stem clearance as close as possible to the end of the guide (at 0.4/0.05" front the end due to poor access). So real clearance is a bit lower but not that much.
The guy at the shop said the play is not that bad.
But I have a set of new guides and new valves.
Now, price to drill the heads (there are no guides from OEM) and install new guides is killing me (250 EURO per head) but I think I have no choice ...
Old Mar 26, 2013 | 09:50 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
When you do new guides you need to redo the seats and valve job because its near impossible to get new guides in that keep valve at the right angle with the current seats. Thats probably where the cost is coming from
I am in this position right now. My play was so bad its amazing i didnt drop a valve probably over .030" haha. Thats what bad rocker geometry will do
Old Mar 26, 2013 | 10:29 AM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Since when? we do it all the time so dont say it cant be done.
To the original poster, On a new typical bronze guide deal we set them at 0.0014 intake and 0.0018" exhaust. Anything above 0.0028-0.003 dosnt pass.
camaro71633
Sep 1, 2015 10:24 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
Out-Cast
Aug 17, 2015 10:57 AM
matthew911
Aug 12, 2015 09:38 AM
gwade12
Aug 8, 2015 08:17 AM
