Radiator leaking (is there a fix?)
Old Mar 26, 2013 | 04:24 PM
wishoradream's Avatar
Car: 1982 Z28
Engine: 388 SBC
Transmission: TH350 Lockup
I've got a 4 core radiator, the area where the transmission lines screw in, I have coolant leaking out around the nut that screws onto the threads. Is there supposed to be a rubber washer or something on there? there is a metal washer, but how is that supposed to seal it ???
Old Mar 26, 2013 | 06:25 PM
Car: 1982 Z28
Engine: 388 SBC
Re: Radiator leaking (is there a fix?)
I fixed this one, lol just threw a rubber thick washer on it, stopped the leak, Not sure what the guy before me was thinking using metal as a seal....
Old Mar 26, 2013 | 08:13 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
You have coolant coming out of trans cooler line? May want to check trans fluid
Old Mar 26, 2013 | 08:18 PM
Car: 1982 Z28
Engine: 388 SBC
No no, it was antifreeze/water, leaking around where the trans cooler line goes, not the actual fitting, or line, but from the tank. I sealed it up, Looks like it'll be fine.
my86bird
Oct 23, 2015 12:20 PM
TheTraut88
Sep 11, 2015 05:16 AM
Ron U.S.M.C.
Sep 7, 2015 08:38 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
