lt1 running hot
Old Mar 31, 2013 | 02:40 PM
87tunedport's Avatar
Car: 1986 Pontiac Trans Am
Engine: 5.0
lt1 running hot
what can cause an lt1 engine to run hot? i already checked the oil and found no milky residue, coolant is clean, water pump was replaced new thermostat too, did a radiator pressure test and holding 16lbs, so i dont think i have blown head gasket or cracked head (worst case scenario) timing is at factory setting, electric fans are running, only thing i never looked into is the radiator. any other suggestions? btw its in the 40s in MI so its not that hot around here
Old Mar 31, 2013 | 03:44 PM
Engine: 5.0
Re: lt1 running hot
update: i just noticed on my fans the driver side runs when ever the engine is running but will not run when key is switched to "on" with engine off the passenger side does not run at all. is this normal? the passenger side fan is right next to lower radiator hose
Old Mar 31, 2013 | 09:52 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Re: lt1 running hot
LT1's will run hot if they have air in the cooling system. They must be bled using the factory procedure. They will not purge air like a normal SBC.
Old Apr 1, 2013 | 02:47 PM
Engine: 5.0
Re: lt1 running hot
a shop replaced the water pump for me and tossed in the new thermostat so it would seem to me they would bleed the system but ill try to burp it
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
ezobens
Aug 19, 2015 10:29 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
