Cam advice!
Old Apr 4, 2013 | 07:41 PM
smallblockbrad's Avatar
Cam advice!
Ok, im in the process of building a 350 for my z28, im going carb and ive so far changes all the gaskets, installed a new oil pump and am collecting parts for the build. for now im using the stock heads, with a rpm performer intake from edelbrock, and a edelbrock carb. Im not sure what size. My question is what cam would you guys suggest, if im gonna be swapping to stock vortec heads and an edelbrock intake for the vortec heads in the future once i get some more funds saved up. Any input would be greatly appreciated. Also my block is two bolt main. I believe 0010 casting.
Old Apr 4, 2013 | 07:44 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Cam advice!
What is the intended use? Compression, trans, converter, gears, suspension?
Old Apr 5, 2013 | 04:45 AM
WorkmanLt1's Avatar
Car: 1995 Trans Am
Engine: 5.7 LT1
Re: Cam advice!
What year is your 350? What year is your z28? Is it auto or manual?
Reborn756
Sep 4, 2015 03:42 AM
lt1z350
Aug 28, 2015 05:57 AM
neekolzun
Aug 24, 2015 04:59 PM
stalkier
Aug 21, 2015 01:54 AM
Hello, Michael
Aug 20, 2015 03:19 PM
