Oddball Question: Orientation of Sock on Fuel pump
Old Apr 5, 2013 | 08:23 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Somehow I forgot to note the direction of the fuel pump sock when I pulled the pump out of the tank to install the walbro. The walbro's sock is one-sided like an L, while the original stock was more like a "T".
So, because of the way the tank sits it didn't make sense to install it with the sock orientated 90* perpendicular to the Sender's float, and I think I remember pulling it out with the stock orientated parallel to the sender float.
I installed it with the sock facing away from the sender, but parallel.
I know, stupid question. And I should have noted it when pulling the fuel pump out, but I apparently forgot.
Was a long job. By myself, hand tools, laying on crappy, rocky driveway. No help to be found. 6 hours. But I also removed the axle entirely for the swap because I have a bunch of UMI stuff to go onto the car.
Old Apr 5, 2013 | 10:30 PM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
Re: Oddball Question: Orientation of Sock on Fuel pump
After reading all the fuel pump heat issue threads I believe if you have the L style sock it should be pointing away from the return line. The idea behind it is not to get hot return line fuel to go right back into the feed. That is how I installed mine and have had no issues.
Old Apr 5, 2013 | 10:33 PM
In that case I'm probably fine then because the return line is on the same side as the float.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
