Transmission?
Old Apr 7, 2013 | 11:11 AM
Tandyman's Avatar
Transmission?
Hey guys I have an automatic 1992 Camaro RS. It has a V8 in it. So let me tell you whats happening. I was driving it the other day and I was driving it up a hill, it wouldn't shift into a lower gear and took forever to get to the top of the hill once at the top of the hill it stalled. I started it again and made my way home. Driving down a hill or in a flat area it would maintain speed but to get it to shift I have to take my foot off the gas and then immediately put my foot on the gas again. I can then feel it shift. When I got into the driveway it staled again. It wouldn't start. I let it sit for 10 minutes and then it started again. Other then that time it starts up fine. It also idles fine when its in park when I put it in Drive and keep the brake compressed it wants to jolt forward. Would this be the transmission or a fuel pump? Thanks
Old Apr 7, 2013 | 01:50 PM
ex-x-fire's Avatar
Re: Transmission?
Kinda sounds like the torque converter is staying locked up. But that would only act funny at very low speeds or idling in gear. Make sure your tv cable isn't broken, this is a cable that hooks on the throttle arm of the tbi unit, unhook off the stud & pull it, it should feel springy.
Old Apr 7, 2013 | 04:09 PM
Hello, Michael's Avatar
Car: 1987 Pontiac Firebird Trans Am WS6
Engine: SBC 350
Axle/Gears: 3.70:1 BW M78 9-Bolt Posi
Re: Transmission?
Yeah, it could be a bad torque converter lock up solenoid, or the throttle valve cable needs to be adjusted.
Old Apr 8, 2013 | 10:26 AM
Tandyman's Avatar
Re: Transmission?
I checked the tv cable and it is fine. Where can i locate the torque converter? And is it a hard fix?
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Youngs92
Sep 23, 2015 11:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
