Electrical....FML
Old Apr 10, 2013 | 06:02 PM
Ikes 91Z's Avatar
Car: 1991 Camaro Z28
Engine: LS Conversion
Axle/Gears: Stock for now...
Electrical....FML
Needing some help with what I am thinking is an electrical issue. My gauges are only half working. My speedometer doesn't work (neither does the odometer), my tachometer moves, but says I idle at 5k rpm's (obviously inaccurate). Has anyone had this issue before? What are some ideas of what I need to look at?
Old Apr 10, 2013 | 07:13 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Electrical....FML
Originally Posted by ericeickhoff
My gauges are only half working. Has anyone had this issue before? What are some ideas of what I need to look at?
Going to require alot more investigation on your part; check cluster grounds etc
a factory service manual would be handy for the diagnostic charts
tacho problem is well documented
https://www.thirdgen.org/forums/elec...meter-fix.html
Old Apr 11, 2013 | 07:50 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Turn the park lights on & off and see if the gauges change. Do this with the cluster lighting turned up bright. If the gauges change when turning the lights on & off it is likely a ground problem to the cluster.
RBob.
