no EST bypass mode ???
Old Apr 13, 2013 | 02:54 PM
1984HO's Avatar
Car: 1984 Z28
Engine: LQ9 W/ Howards ASA cam+Fast 90
Transmission: T56 Mgw shifter
Axle/Gears: Currie 9inch w 4.30 gears
hey guys not sure if this is the right section for this ...mods feel free to move
anyways just installed an HSR on my l98 , the problem i have is when i disconnect the est bypass , the check engine light comes on just like it should however the engine sound does not change, according to tunepro spark relative to tdc is still at 18 degree's +/- , and my timing light would seem to indicate it has that much advance or more ( my light does not have advance). im thinking the issue maybe the module (ignition module in dist) , anyone run into this before ????
Old Apr 13, 2013 | 10:17 PM
ex-x-fire's Avatar
Re: no EST bypass mode ???
Does it advance when you rev it (w/ bypass hooked up)?
Old Apr 13, 2013 | 11:37 PM
1984HO's Avatar
Car: 1984 Z28
do you mean with the bypass unplugged ...that I'm not sure of ...with everything plugged in the car runs fine.I went to harbor freight tonite and got a timing light with advance so I should be able to figure out better tomorrow exactly what is going on
Posted from Thirdgen.org App for Android
Old Apr 14, 2013 | 07:49 AM
ex-x-fire's Avatar
I just wanted to know if it functions correctly w/ the bypass hooked up.
You know that your not supposed to unhook the bypass while its running.
$750 L98
Feb 1, 2025 02:25 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
L98GTA87
Oct 19, 2015 10:43 PM
327IROC85
Sep 23, 2015 12:11 AM
Formula8r89
Sep 22, 2015 04:24 PM
