can i still get trouble codes?
Old Apr 21, 2013 | 10:13 AM
87tunedport's Avatar
Car: 1986 Pontiac Trans Am
Engine: 5.0
im having issues of idling real low. sometimes i get the SES light, but goes off next key cycle. it is currently not on, can i still get codes? i tried doing the paper clip thing but only got 12 it just keeps flashing that
Old Apr 21, 2013 | 12:36 PM
Vader's Avatar
Re: can i still get trouble codes?
Check this one:
https://www.thirdgen.org/forums/post...141-post9.html
If there is no misfire, and only a low idle, there may not be a stored error code. I'd start by checking the IAC, its air passages, the throttle body, and the setting of the TPS. Cleaning the IAC, the IAC air passages, and TB are common service/maintenance items. Once clean, if the problem persists, check the TPS voltage per the service manual.
If there is a misfire, start looking at the pickup coil, ignition module, its wiring, and the ESC module.
Don't just start replacing modules and parts. Perform some diagnostics first.
Old Apr 21, 2013 | 05:59 PM
Engine: 5.0
Originally Posted by Vader
Check this one:
replaced IAC, TPS voltage at .67, cleaned passages and new TB gasket kit. how do i perform diagnostics? i dont have scanner
Old Apr 21, 2013 | 06:49 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by mustangIIfan
TPS voltage at .67,
Too high
Reset the TPS to the correct value
DIAGNOSTICS = testing ,evaluation , following a fault flow chart to work out what your problem is
Hopefully by using the factory service manual for your car
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
Lmancha96
Sep 25, 2015 08:11 PM
