Hot starting issues
Old Apr 21, 2013 | 03:06 PM
Keith Yee's Avatar
Hot starting issues
Hello I have a 87 tpi 350. I have a problem starting the car when it is hot. I starts fine when it is cold. I recently changed the fuel pump , fuel filter, and fuel regulator. the static fuel pressure test is 46 psi when cold. When hot the pressure doesn't built that fast and it doesn't get to 46psi when the static test is on hot. Can someone please help? Thanks.
Old Apr 25, 2013 | 10:49 PM
Keith Yee's Avatar
Re: Hot starting issues
Hello Anyone there?
Old Apr 26, 2013 | 04:28 AM
conlinj's Avatar
It may be the starter.
Old Apr 26, 2013 | 06:26 AM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
OK, so what pressure DOES it make when hot?
What tests have you performed on your cranking system?
Old Apr 26, 2013 | 06:29 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Could be the starter, battery,cables, might be time to do some testing.
Old Apr 30, 2013 | 07:56 PM
Keith Yee's Avatar
Sorry for the late response, when it hot starts it goes to 46 psi. The starter was recently replaced too
theshackle
Mar 5, 2017 06:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
TheExaminer
Aug 26, 2015 04:59 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86Base
Aug 8, 2015 01:34 PM
