Fuel Pump Problem
Old Apr 24, 2013 | 09:33 AM
carattini's Avatar
Car: Pontiac 89 GTA
Engine: 350 TPI 5.7L V8
Fuel Pump Problem
Hi: My 1985 Trans AM with 305 TPI fuel pump died. I replace it and it work Good for a While about tow Months. Know it shotdown by it self running I'm thinking an electric problem so if any one have a diagram or where are located the electric component to check I'll apreciate any help.
David...
Old Apr 24, 2013 | 04:28 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: Fuel Pump Problem
Since you replaced the pump, I would start by checking for power to the pump at the four pin connector just above and in front of the fuel tank. If this is an 85, the tan wire is power to the pump, if it's the 89 in your signature, it's the tan and white wire. The wire should have power for 2 seconds when the key is turned on and should have constant power when the engine is cranking or running. If you find no power there, check the fuel pump/ECM fuse that is close to the battery in a black fuse holder that should be attached to the passenger side fender well.
The fuel pump relay is located on the firewall above the brake booster. There are a few relays in that area and they are all the same relay. If this is an 85, look for the relay with two large orange wires, a small black and white wire, small light blue wire, and a small green and white wire. If it's an 89, the relay has a large orange wire, a small red wire, a small tan and white wire, a small green and white wire, a small black and white wire. There should be ground on the black and white wire at all times. There should be power on the orange wire at all times. The ECM applies 12v to the green and white wire to turn the pump on.
Old Apr 25, 2013 | 07:49 AM
carattini's Avatar
Car: Pontiac 89 GTA
Wow that is a lot more than I bargain for Thanks very very much. In fact it is my 85 that has a problem my newer 89 has no issue yet. I'll check this and get back to you with the results.
David...
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
