89 Firebird problem
Old Apr 25, 2013 | 11:34 PM
PrinceLuBu's Avatar
89 Firebird problem
I have an 89 poniac firebird 2.8 ltr V6. long story short..... It would crank over but not start, with starter fluid it would start and SOMETIMES even idle. I replaced the distributor, and put in a new coil. I used a timing light to time it BUT for some reason the coil isnt putting out spark. When I first put it in it gave spark and ran for about 3 seconds. When I tried to start it again there was no spark coming from the coil. the main problem is AFTER I bought the car from the guy I learned he likes to rig cars so they run bad and people give them back. I found the fuel clamp wasn't on the main fuel line under the car. and a few other things he did. My main question is... what causes the coil to not give spark?
Old Apr 26, 2013 | 01:55 AM
wbstearns's Avatar
Car: 01 s10 blazer and 89 bird
Engine: 383 with mystery cam - maybe
Transmission: t56 hopefully
Axle/Gears: 373 geared posi from 2002 z28
Re: 89 Firebird problem
Sounds more like fuel issue than spark if it will fire and idle with starting fluid then you have spark my bet would be fuel pressure testing and probably replace the pump and filter and see where your at then
Old Apr 26, 2013 | 11:54 AM
PrinceLuBu's Avatar
Well I got it to idle but then the coil quit giving spark, we replaced the distributor and nothing... We got a new coil and it gave enough spark to turn over one time and run for 3 seconds, then it quit giving spark again. any clue?
Old Apr 26, 2013 | 01:15 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Vehicle anti theft.... commonly known as vats. Does Ur key have a little resistor pellet in it? It should being an 89
Old Apr 26, 2013 | 01:20 PM
PrinceLuBu's Avatar
thats what I thought but my friend says if it was that the it wouldn't crank.....
Glowsock
Jul 24, 2025 03:15 PM
jhawkeye
May 25, 2022 06:33 PM
theshackle
Mar 5, 2017 06:37 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
zeitghaist
Aug 18, 2015 07:33 AM
