HP Numbers
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
HP Numbers
Im trying to see if anybody here thinks this combo is ok and what horsepower numbers are realistic from my combo..
I have a 350 tpi bored. 030
A zz4 cam
A lingelfelter super ram with adjustable fuel.pressure regulator
Probe pistons .030"
Eagle rods with arp bolts
zz4 113 vette heads
Lingenfelter tri y headers
High flow cat
Slp totl exhaust
Th700-r4 stage 2 shift kit
9 bolt 3.27
Aluminum drive shaft
Roller tip rockers 1.5 comp cams
Slp cold air induction
Slp air foil
Msd distributer
Msd 8mm wires
A zz4 cam
Probe pistons .030"
zz4 113 vette heads
High flow cat
Slp totl exhaust
9 bolt 3.27
Slp air foil
Msd distributer
Msd 8mm wires
LT1Formula
Oct 8, 2015 08:34 PM
3.8TransAM
Sep 27, 2015 08:37 PM
