89 firebird formula tpi 305 5spd only start with starting fluid
Old May 11, 2013 | 12:59 PM
codya3204's Avatar
replaced fuel pump, fuel filter, ignition module,rebuilt fuel press regulator, new ecm .. all new . injectors ohm fine and fuel pressure is right. also replaced distributor and timing is dead on. also checked tps switch and numbers are right . only will start with starting fluid and wont take gas when running now...idles real rough about 400 rpm. im lost on this could use a few opinions on what to try next. car has been setting for 3 years because I cant get it to run.
Old May 19, 2013 | 04:13 PM
formuladave88's Avatar
Car: 1988 Formula
Engine: 388ci
Transmission: WC T-5: t56 in the makes
Axle/Gears: 4th gen rear 3.42
Re: 89 firebird formula tpi 305 5spd only start with starting fluid
My 88 had the same problems when I first got it, it was sitting for a long time too, mine ended up being a chunk of burnt/ chewed wires under the dash, when turning the key on, there was no initial pulse from the injectors for start up. The previous owner had done their own wiring for radio or electric fans, overloaded it somehow I guess. I'm no expert, but a new under the dash wiring harness and a few fixed wires and she was back in business. Hope this helps
Old May 22, 2013 | 01:39 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
My first advice is quit replacing parts until you pinpoint the problem. Have you verified power to the injectors? With the key on, you should get 12 volts at both sides of each injector. You can just check one on each side since they are divided into two banks. Then, make sure that you get a flashing light on one side of an injector while cranking. Again you can just check one injector one each bank. Check the injector fuses for power on both sides and be sure that the connection of the 4 pin distributor connector is solid. The purple and white wire is crank reference to the ECM and that's the signal that the ECM uses to fire the injectors. Have you verified fuel pressure to be 40psi at the rails?
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
Bradsaundry
Aug 12, 2015 12:34 AM
drathaar907
Aug 10, 2015 07:44 AM
drathaar907
Aug 6, 2015 04:20 PM
