Need help finding tach wire
Old May 12, 2013 | 08:54 AM
baker440ex's Avatar
Car: 87 Z28
Engine: Roller 305 LG4
Transmission: NWC T5
Axle/Gears: 9 Bolt 3.27 LSD
87 305 CC quadrajet, 700r4, just swapped intake, edelbrock square bore carb, hei distributor. Need to know which wire controls the tach. My previous coil pigtail has a white and a pink wire on it, Im using the pink as my 12V power source to my distributor, I was thinking the white was the tach but I tried it and it's not...Help!!
Old May 13, 2013 | 07:59 AM
Re: Need help finding tach wire
Yes, white is the tach.
Old May 16, 2013 | 07:55 AM
baker440ex's Avatar
Car: 87 Z28
Well something's not right, I tried the white one and the tach pegged at zero. I was working on the car in other places too. Anyhow when I went for a road test my volts gauge was also pegged at zero and what I had done was blown the gauges fuse. Now that Ive gotten rid of the computer does that mean I need an aftermarket tach?
Old May 16, 2013 | 06:06 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Computer has nothing to do with the tacho.
The tacho signal goes straight from the coil Neg terminal to the Tacho ( white wire )
I would be checking ( with a the cond of the white wire from the coil to the conector for the gauge cluster at the dash
Old May 16, 2013 | 06:08 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
I would be checking with a DVM the cond of the white wire from the coil to the connector for the gauge cluster at the dash
Old May 17, 2013 | 02:07 PM
baker440ex's Avatar
Car: 87 Z28
Ok Vetteoz you are correct on the white wire. Guess I had to take the cap off to get it right, and must have hit the positive lead the first time. Thanks for the help and patience
eightsixseven
Dec 16, 2024 01:50 PM
Jeremys87
Jul 14, 2022 09:08 PM
Caspar
Jun 19, 2016 11:19 PM
stalkier
Aug 7, 2015 04:49 AM
