Timing help with 350 and New MSD DIST.
Old May 20, 2013 | 05:45 AM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Hi, I am installing a New MSD Billet Dist Vac advanced Dist, I have a 350 Chevy with a Holley 650 Ultra DP Carb and the rest of the mods are in the sig below, Where should I start with my timing numbers?
What about total timing?
I was thinking around 8 Intial and 32-36 Total?
Old May 20, 2013 | 11:57 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Timing help with 350 and New MSD DIST.
Need to know the cam grind to give a ballpark ignition timing.
Old May 20, 2013 | 08:01 PM
BLACK Z's Avatar
Car: 86 Z28
Stock can at teh moment that came in the GoodWrench 350.
Old May 20, 2013 | 08:39 PM
bygddy's Avatar
Standard 250hp Goodwrench replacement cam
195/202 @ 0.050
Start at 10* but likely better at 14*
290hp GM crate motor
222/222 @ 0.050
16*-18* initial.
Limit vacuum advance to 12-16* total, use full manifold source.
Clean crisp idle.
Limit total mechanical to 36* total all in by 3000rpm.
Old May 21, 2013 | 07:07 AM
BLACK Z's Avatar
Car: 86 Z28
Where did you get those numbers from? I'll give it a shot. Thanks
Old May 21, 2013 | 07:59 PM
bygddy's Avatar
The cam specs? Or my suggestion for timing?
Cam specs, I have had both motors...wasn't sure about the smaller of the 2, its been awhile lol, the other 290hp motor I had last year in my 56 Olds so I remembered what it was.
Timing? Trial and error.....
Old May 22, 2013 | 08:56 AM
BLACK Z's Avatar
Car: 86 Z28
Gotcha. I'll give it a shot, I figure 8 Deg would be the starting point, But I'll try ten Plus.
theshackle
Sep 17, 2020 08:26 AM
apo_bailon15
Mar 28, 2016 05:20 AM
db057
Aug 22, 2015 08:17 PM
midias
Aug 15, 2015 05:07 PM
tartagliaz28
Aug 15, 2015 10:59 AM
