What do these connectors go to?
Car: 1987 IROC-Z Camaro
Engine: 305 LB9
I'm guessing the red one is charcoal canister, the middle bottom one is coolant temp gauge, the one on the right is AC. What is the top one???
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: What do these connectors go to?
Red one, I'm not sure. Flat black one is for the A/C clutch. Roundish one goes on the A/C pressure switch. Little broken yellow one is for your temp sending unit.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The red one goes to the ccp solenoid .
Engine: 305 LB9
So the sender on the block just has a little **** on the end, I dont see how the connector plugs in...
Engine: Lb9
Transmission: M20
The plastic looks broken but if the terminal has good tension it will slide over the nail head.
http://www.repairconnector.com/produ...Connector.html
TMZIrocZ350
Oct 7, 2015 12:09 PM
tmork454
Sep 29, 2015 06:33 PM
