need suggestions on carbed 305 build
Old May 22, 2013 | 09:02 AM
89formyoula's Avatar
Car: 89 formula
Engine: bolt on 305 tpi
Transmission: 700r
Axle/Gears: 342 posi
Alright before I get strarted, I'm not going the 350 or 383 route, im sticking to the 305, I've read a few articles with great info, but no exactly what I need, I have a bone stock knocking 305 with 416 heads, I was planning on exchanging my 305 for a fresh 30 over 305 with flat top pistons...I want to use my 416 heads, they will be ported and polished..what can would be best with this combo? And should I do anything about the stock valves? I'm not trying to make a drag car, this car will be driven almost everyday, just trying to make a 305 that doesn't disappoint.
Old May 22, 2013 | 09:03 AM
Car: 89 formula
Transmission: 700r
Re: need suggestions on carbed 305 build
Cam*
Old May 22, 2013 | 02:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
So, carbed, not TPI.
Are you rebuilding the knocking engine, or finding a different shortblock? What's most important is whether it'll have roller lifters or not. Once we know that, we can talk cam specifics.
For a daily driver that has a little more umph, the stock valves will be fine. Plan on new valve springs to match whatever cam you end up getting.
Old May 23, 2013 | 06:04 AM
Car: 89 formula
Transmission: 700r
non-roller, i'm sending the knocking engine in it off as a core charge and getting a long block built.
Old May 23, 2013 | 06:11 PM
Car: 89 formula
Transmission: 700r
but hes gonna let me use my heads, i want to send them off to be worked, i heard theyre decent heads, i just have no clue what cam would work well with the combo.
Old May 25, 2013 | 04:56 PM
Car: 89 formula
Transmission: 700r
Anybody? Anything?
theshackle
Sep 17, 2020 08:26 AM
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
makaveli09
Aug 12, 2015 09:07 PM
