Check Valve Differences?
Old May 26, 2013 | 08:47 PM
THCARGUY's Avatar
Car: 1985 & 1991 Trans Ams
Engine: 350 in both
Transmission: Auto in both
Axle/Gears: 3:23 Limited Slip in both
Hi! On my 91 TA with the 350 TPI Engine there are three of these Black Metal Check Valves. Two of them have a number 22041203 on them and the other shows 22036195. They look physically the same. Are they the same? Thanx!
Old May 27, 2013 | 07:33 AM
Re: Check Valve Differences?
Yes
Old May 27, 2013 | 04:05 PM
THCARGUY's Avatar
Engine: 350 in both
Yes
In that case I just have to ask the obvious. Why did GM have a separate part number for them? They show the #22036195 Valve as part #22048224 and the 22041203 Valve as part #22040897. Confusing!
Old May 27, 2013 | 06:33 PM
Prolly came from 2 different sources (parts supply plants) or something profound like that.
It's just a check valve. Lets air go one way, but not the other. If it does that, and has the right fittings, then it's THE SAME, or at least, THE SAME ENOUGH for the purpose at hand.
Don't outsmart yourself over something THAT simple.
Old May 28, 2013 | 07:59 PM
THCARGUY's Avatar
Engine: 350 in both
You're absolutely right. I just wanted to make sure that I had it right. Thanx for the insight!
backtothe80s
Sep 5, 2015 12:39 AM
Out-Cast
Aug 17, 2015 10:57 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
