no spark HELP PLEASE
Old May 29, 2013 | 06:05 PM
1buells1's Avatar
Car: 82 z28
Engine: 350 sb
Axle/Gears: 10 bolt
I started up my 82 z28 was running just fine and as i go to walk awayand she died i tried to start it back up just turned over pulld a plug and grounded it and there was no spark so i was told it might be my ignition switch so i changed that turn the key and it just turns over still no spark i have a fairly used delco remy hei distributor with 4bbl,350sbc battery is good connections fuses are good maybe a relay or fuse i dont know about distributor is still rotating. Thanks any questions or suggestions please feel free
Last edited by 1buells1; May 29, 2013 at 06:20 PM. Reason: added more specifications
Old May 29, 2013 | 06:42 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: no spark HELP PLEASE
http://easyautodiagnostics.com/gm_ic...n_module_1.php
Old May 30, 2013 | 02:49 AM
Redchevy808's Avatar
Car: 1992 camaro rs
Engine: 92 350ci carbed
Transmission: 700r
Axle/Gears: Stock 10 bolt 2:73 gears 😭
Is the power wire going to your distributor all good? Mines did this and the wire was loose. Unplug and plug back in just to check
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
