1992 L05 (350) with 89 L98 heads and cam & TPI
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
My current engine has knocking someplace internally. I decided to pull the motor (next weekend) and switch it for a good running L05 TBI out of a GMC conversion van. My question is:
The L05 is from my research a 9.3:1 compression engine with swirl heads. What I want to do is switch out the complete top end of my L98 (except my motor is a crate with 217 64cc heads) onto the L05 as well as the oil pan for the Camaro and the Camaro exhaust manifolds. I also want to switch out the cam out of the L98.
Is there going to be any issues with this simple conversion? Am I missing anything that I might also need to think about?
I will be putting in a new oil pump, timing chain and gaskets. I will be using 24lb injectors that I had on the L98, new distributor/Delco module. When I installed the 24lb injectors last year I did not have the car tuned. Will I need to do this for the chip? I really would like the advice. Thank you in advance.
Factory specs on the L05 - It had 9.3:1 compression ratio, 193 head castings(1.94/1.50 valves 64 cc chambers),a cam that measures 248/252* @ .008, .382/.401 lift, 109* lobe separation, installed on a 112* intake centerline.
Car: 2002 Pontiac Trans Am WS6
Axle/Gears: 3.73 posi
Re: 1992 L05 (350) with 89 L98 heads and cam & TPI
Shoot me a PM and I'll fiil you in on my '92 L05 swap into my '84 Corvette. Ditching the CFI for TPI along with a Speed Pro cam and long tube headers.
Later,
Lee
Later,
Lee
The L05 cam is trash; WAY smaller than the L98 cam, and flat-tappet besides.
Other than that, the other parts will bolt up just fine.
84z96L31vortec
Aug 20, 2017 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
