Timing Cover Help!
Old Jun 11, 2013 | 07:09 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Timing Cover Help!
I am in search of a timing cover.
The cool aluminum one I got will not work. The oil pan will not seat on the block with this one.
I've noticed most timing cover listings mention they will not work with a 1 piece rear main seal block.
I have also noticed some of the stamped steel ones listed for one piece blocks say they will not clear a roller timing chain.
SO, I have a one piece rear main seal block, and a roller timing chain.
Anyone have any suggestions?
Old Jun 11, 2013 | 07:38 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Timing Cover Help!
Why not use stock L98 one?
Old Jun 11, 2013 | 09:04 AM
Car: 1971 Camaro
Engine: 427
I don't have one.
Old Jun 11, 2013 | 12:03 PM
Car: 1971 Camaro
Engine: 427
Got an email from Canton, they sell one that works with the 1 piece rear main blocks.
Got it on the way.
Old Jun 13, 2013 | 08:51 PM
Car: 1971 Camaro
Engine: 427
Got the canton cover installed, but the lip on my one piece oil pan gasket still seems too thick.
The gasket came in a fel pro 2664 kit which is supposed to be for a 1988 corvette.
Guess I'll go to the local parts store and compare different pan gaskets.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
I'llrocya
Feb 2, 2016 11:43 PM
NBrehm
Aug 25, 2015 11:49 PM
