Mystery Gaskets
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Mystery Gaskets
Those gaskets are for a water pump, and a oil cooler adapter .
Car: 1971 Camaro
Engine: 427
Re: Mystery Gaskets
Which is which?
Big O rings for water pump, and circle gaskets for a cooler?
Engine: 4++,350 & 305 CIs
Re: Mystery Gaskets
the 2 rubber gaskets are for the 2 diff style oil coolers to block and the 2 bottom paper gaskets are for the 2 diffferent oil cooler adapters that bolt to the block.
Re: Mystery Gaskets
In a "kit" you wont always use all the gaskets. They give you extras to cover some options thru the years
Car: 1971 Camaro
Engine: 427
Re: Mystery Gaskets
Yeah, I've done a few sbc's but never one with the factory cooler, so these kinda suprised me.
I don't have the cooler with this engine so I did not have the part to compare too.
