low rpm missing
Old Jun 18, 2013 | 05:40 PM
t300's Avatar
Car: 1988 iroc red t top
Transmission: 5 speed
low rpm missing
i have a 88 iroc 305 5 speed, replaced distributor, coil, plug wires, plugs,
egr valve,mass air flow sensor, cleaned the iac valve. set timing to o deg
before pluging in gray wire on firewall. ohmed fuel injectors all are 16 ohms, fuel pressure is 40 psi. the motor runs great from 1500 rpm to red line but acts like
its running on 6 or 7 cylinders at idle engine speeds.
also no diagnostic codes.
any and all ideas would be gratefully appreciated......
thanks for replys.
Old Jun 19, 2013 | 03:07 PM
Tx 91Z28's Avatar
Car: 91/Z28/69SSCamaro/72Cheyenne
Engine: 350/350/350
Transmission: 700r4/400/350
Axle/Gears: 3.23/4.56/4.11
Re: low rpm missing
Sounds like you covered everything . That leads me to ask if you checked compression ratio? Compression, fuel & fire ... With that stated have you doubled checked all of your vacuum lines under the hood & dash for a leak? have you cleaned the injectors as well?
Old Jun 19, 2013 | 03:41 PM
t300's Avatar
Re: low rpm missing
vacuum leak ?
i have checked under the hood for a un plugged vacuum line, but
diddnt think about under the dash. thanks for a new direction troubleshooting this problem.
also question on the injectors, they all are the same resistance and dont leak down with the ignition off. i thought if they were messed up they would be more of a problem at
midrange and higher rpms. my car only misses at idle and right above idle.
thanks for the help
Old Jun 19, 2013 | 04:42 PM
Tx 91Z28's Avatar
Engine: 350/350/350
Re: low rpm missing
There are people in here more experienced with injectors than I . but my thinking is if one is spraying ugly it cause a miss fire at low rpms. Too Much fuel or too little?
Old Jun 26, 2013 | 03:00 PM
t300's Avatar
Re: low rpm missing
you were exactly right, i replaced the injectors and it runs like new again....
the oem injectors were filthy
90k on car but it has sat stored for much of its life.
another thing these cars were not designed with maintenance in mind
the tpi system and fuel injector system is a PIA to work on.
thanks again
Old Jun 27, 2013 | 01:42 PM
Tx 91Z28's Avatar
Engine: 350/350/350
Re: low rpm missing
thanks again
I am glad you got it fixed.
eightsixseven
Dec 16, 2024 01:50 PM
jklein337
Sep 19, 2018 06:23 PM
Jake_92RS
Aug 17, 2015 09:42 AM
jackhammer
Aug 15, 2015 10:04 PM
perZ
Aug 15, 2015 01:17 PM
