Start up oil and break in oil?
Old Jun 27, 2013 | 11:30 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Its been posted a bunch, but I wanted to ask for my specific application. I have a 69 block with hyper pistons, cast rings, COMP cam, stock heads and oil pump. I know i need some kind of oil with ZDDP additive. From what I've read, i should do the initial start up with conventional, change it out after the first 30 min of break in time.
Once I've done that, can I change to synthetic or should I stick with conventional for the first few hundred miles for overall break in?
Sorry for posting the same stuff over again, I just wanted opinions on my application, since everyones build is different.
Old Jun 28, 2013 | 06:33 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Start up oil and break in oil?
i'd avoid the synthetic for a while.
ive been using valvoline vr-1 racing oil for years. it has the added zddp in it.
Old Jun 28, 2013 | 09:29 AM
drdave88's Avatar
Engine: 6.0L
I'm assuming I should run 10w30?
Old Jun 28, 2013 | 10:03 AM
beths91camaro's Avatar
Car: 87 Iroc vert, t-top
Zinc additive for break in- 10w30 is fine- at least that's what we've used in the multiple engines built.
Old Jun 29, 2013 | 06:33 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
if its a hydraulic cam/lifters, you'll need oil with zddp for the life of the motor/cam. not many oils have it today.
viscosity is up to you. 10w-30 is a good break in oil.
theres horsepower to be had in oil. a friend of mine builds pro stock motorcyle engines. one day he tested a bunch of different oils on the dyno. he found that redline oil made the most power. sorry, dont remember the viscosity. i'm sure it was "thin".
another guy told me he picked up 7 rwhp on the dyno just by using royal purple synthetic gear lube in the rear!
anything to free up h.p. is a good idea. the only reason i personally dont use synthetic oil is alot of people complain about leaks after switching. could just be a rumor though?
Orr89RocZ
Apr 25, 2016 08:28 AM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
MY87LT
Aug 17, 2015 08:43 AM
92camaroJoe
Aug 13, 2015 06:07 AM
