Lets play: Name that Dyno!
Old Jun 28, 2013 | 08:38 PM
Chuck84TA's Avatar
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
Lets see who can determine what you think the final hp/tq numbers would be given a specific engine/exhaust set-up:
Stock (per Mfg.) HP= 190 TQ = 240
Situation #1
Type of engine = L69
Engine/carb/intake/heads= Stock
Spark plugs/rotors/wires= changed in last 12 months
Headers =Hooker 2055 headers
Exhaust = Magnaflow 49 state cat converter and cat back. 3 inch pipes.
New hp #_____
New Tq #_____
Situation #2
Same as above but with ported 1.94/1.5 416 heads
New hp #_____
New Tq #_____
Old Jun 28, 2013 | 10:19 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Lets play: Name that Dyno!
Stick it on a dyno and find out. I doubt the stock rating won't even match the dyno results.
Old Jun 29, 2013 | 08:21 AM
It will be less than whatever you think. Always is.
Old Jun 29, 2013 | 02:02 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
It also depends on the brand of dyno.
Old Jun 29, 2013 | 03:33 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
I'd guess theoretical internet dyno?
Old Jun 29, 2013 | 04:51 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Theoretical?
-20% to +50% change.
Old Jun 30, 2013 | 12:35 AM
Chuck84TA's Avatar
Yes, theoretical or based on someone else's experience. Also trying to have fun with this at the same time...
It seems that these possible mods to the 305 run into a variety of hypothetical conclusions. I just want to see if anybody has first hand experience with these situations and can provide some data so there can be some expectation as to what to be expected.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
LT1Formula
Oct 8, 2015 08:34 PM
BBSDesigns
Sep 22, 2015 03:08 PM
