Advice needed,
Old Jun 29, 2013 | 12:27 PM
James Sutton's Avatar
Car: 1991 Camaro RS yellow
Engine: was '91 V6, now '89 5.7/355 TPI
Transmission: 4 speed automatic
Axle/Gears: Moser 3.73 with zexel posi
Advice needed,
My engine warning light on 1991 RS comes on sometimes on a cold start. Car runs okay, but at reduced power. If I put the hammer down, car strains, power comes back, warning light goes out. Being an English major, I don't have equipment to check codes & would like a clue as to what the problem is.
Some things to know: Car was three years in body shop as project car for high school; primer dust on everything. Since it came out three weeks ago, I've replaced battery, alternator, reset timing to zero (engine was swapped out from 3.2L to 5.7), fuel pump (bigger one needed for 5.7L), and starter (plus headliner, dashboard, power seats with harness, glove box), Tranny is from 5L 1987 Camaro RS. Engine has performance crank and a getting worse rear seal leak, probably from drying out in the shop. Engine is new (not rebuilt) with less than 500 miles; car has 154,000 miles. Battery switched from L to R side. There was a weird wire to the electric cooling fan, making two, and that was fixed by rewiring. And the radio was wired to the ignition without a fuse; took care of that. Do I have a tranny problem? It was checked, but has 100,000 miles on it. Feels electrical, somehow.
Old Jun 29, 2013 | 08:53 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Advice needed,
No skill needed
https://www.thirdgen.org/forums/tech...s-dumbies.html
Pull the codes and start a new thread about them
what the codes mean
http://www.iroczone.com/2009/10/1982...maro-firebird/
Old Jun 30, 2013 | 08:06 AM
Re: Advice needed,
Thanks, Vetteoz. Where will the codes display? I have an analogue instrument cluster. Do I need a PC connection?
IROCZ1989
Jan 24, 2016 03:55 PM
dutch930
Sep 11, 2015 06:58 AM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
