Anybody looking for vacuum pump install brackets?
Old Jun 30, 2013 | 09:20 AM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
http://m975.photobucket.com/albumvie...10945.jpg.html
I designed a set of vacuum pump brackets for use on a 434 I built for a guy....if you want to retain a stock GM serpentine setup, this kit uses a smog style RH bracket and the Moroso pump installs easily....this was my mockup design and requires the use of a 3 to 1 diameter reduction from crank pulley to vacuum pump pulley to reduce pump speed. The pulley is an area you'd have to decide on.....I just built the bracket kit from a water jet CNC.
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
red90IROCls1
Aug 25, 2015 06:56 AM
kyleb24
Aug 15, 2015 08:24 AM
