355 single plane EFI dyno results!
Old Jun 29, 2013 | 12:51 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I made it out to the Dyno (Mustang) a few days ago and thought I would post my results for people thinking about similar combos in the future. I mainly used the dyno for final tuning of my VE table and then did a couple power runs to finalize my air:fuel ratio up top. The final power numbers were in the expected ballpark for this combo so I didn't sit there and try all kinds of little adjustments. Total timing was 33-34* (I say 33-34* because I went with a chromed balancer and it is very difficult to read exact!) and my air:fuel ratio was 12.5-12.75 at WOT verified by my Innovate Wideband.
Horsepower was 322 at about 5,850 RPM
Torque was 308 at about 4,000 RPM
I have read/heard that the Mustang Dynos are known to read low, some local people have told me its probably more like 350-360 horsepower and about the same for torque.
The engine itself was built by me a few years back (and will be pulled soon for my 383)
355 4 bolt main vortec block
Keith Black Hypereutectic Pistons around 10:1 CR
Trick Flow Heads I ported
1.6 aluminum roller rockers
LT4 "Hot" cam
Accel single plane EFI intake
1200 cfm 4 barrel progressive throttle body
Bosch III 30 lbs/hr injectors
AFPR set at 43 psi
Hooker Super Competition Headers (1.75 to 3")
MegaSquirt 3 Extra Engine Management Controller
Attached Thumbnails 355 single plane EFI dyno results!-dyno-sheet-1.jpg   355 single plane EFI dyno results!-dyno-1.jpg
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
darwinprice
17
Oct 11, 2015 11:51 PM
dusterbd
Sep 29, 2015 08:40 AM
ndndndnd
Sep 28, 2015 08:00 AM
JSDaddy189
Sep 26, 2015 03:50 PM
