Weird, weird won't start problem
Old Jul 2, 2013 | 09:00 PM
Untamed Z's Avatar
383 Super Ram engine having problems starting. When you crank the key to the START position it will absolutely not start. If you just bump the key (like if you're setting the timing) it will start anywhere from the third to eighth "bump". Injectors have pulse when you bump it, but don't or very weak in the START key position. Once the car starts, it's fine. Turn it off, same problem everytime. Need help because I'm having trouble figuring this out. Thanks
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
