Recessed lip in lifter bores?
Old Jul 3, 2013 | 03:12 PM
zraffz's Avatar
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
I picked up a 14093638 4 bolt TBI block with the proper machining for the dog bones, lifter "studs/towers", provision for cam plate. I will have to tap the holes for the spider plate to bolt down but that's fine.
The lifter bores on this motor are a larger diameter for about .5" and then reduce down to the proper size; giving the lifter bore a "recessed lip". Anybody know what this is about and if its a good or bad thing? They are all even and must have been done by GM.
Old Jul 3, 2013 | 05:49 PM
zraffz's Avatar
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
Re: Recessed lip in lifter bores?
Well I accidentally drilled into the oil galley where the cam/bearings sit in 2/3 spots when tapping it for the spider plates. If I put Loctite or something of that nature on the threads, will it work or did I just ruin the block?!
Old Jul 3, 2013 | 06:03 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Im not even goin to ask how, But they bolts are only 1/4-20x3/4 Im sure lock title will help wil the seal and any oil pressure loss would be minimal .
Old Jul 3, 2013 | 06:15 PM
Not Loctite; use thread sealer. I'd suggest the "high-temp w Teflon" product.
That's just the way they did those bores. Not good or bad, really; just, how it is.
Old Jul 3, 2013 | 06:49 PM
zraffz's Avatar
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
Thanks guys. Never saw lifter bores like that so I was nervous. And drilling too far happened cause my tap has recessed threads and I was forces to drill further :/
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
FormulasOnly
Jul 23, 2018 08:47 AM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
Stryker412
Sep 7, 2015 09:11 AM
